1 - 16 of 16 Posts
CarbonFrame
I used to be meticulous.. about every 250 miles. Now, I am using Pedros synthetic chain lube and I must have well over 1000 miles since my last cleaning and everything seems to be relatively clean and QUIET! I'm wondering if I should just leave things alone...
Downhill Juggernaut
About once every 10-12 days on the commuter, but I ride through some gritty stuff and it needs to be done. The road bike gets it about every three weeks or so.
Resident Curmudgeon
Whenever I think it needs it after visually inspecting it. For sure after every rain.
Frog Whisperer
wipes after every ride, thorough about every 200 miles....dirty chain/gears = worn drivetrain ultimately imo
After every ride, simple green the chain and hose it off with power sprayer (really a garden hose with a 1/4 inch spray among others), including chainrings and sprocket . Finish up the job by using a compressor to blow dry the whole drive train. Got tired of using dedicated chain cleaners, paintbrushes, old toothbrush, cuetips and rags.
SoCal--S Beach to the Dam
Well thats an example on how not to clean it.
I am not sure if its the worst way, I think its overkill for a road bike. That type of cleanup is typical of what a mountain biker does after a muddy ride. I run DT Swiss Hugi's that have pressed sealed bearings, I think the argument against hosing the bike down is running water and dirt into the bearings. I know one of my bearing got rusty and needed replacing-about $40 including labor. Not sure if washing was the culprit, probably rain.
Thanks for the comments. I take precautions when washing my drivetrain and dont do the shotgun approach. I aim downwards using the bottom part of the chainline to hose down the chain. Same is true with the chainrings and sprocket, spraying them downwards using 1/4 inch sprayer and aiming for the edges only. This I achieve without any oversprays to other parts of the bike especially the critical bearings, hubs and bottom bracket.
I commute and do the group rides on weekends. Say 120 on average a week. Same with the cleaning, about once a week. Lube? Every other ride. I'm a bit anal. Wax? About every 2 months or so. The ride? Looks like new and rides the same. I have too much invested to let things slide.Trips to have anything fixed by a wrench? 0!
1 - 16 of 16 Posts
