I'd think any bearing grease would would and I happened to have some Vehicle bearing grease laying around. School me.Years back, prior to well sealed BB's, some used Boat Trailer Wheel bearing grease in BB's. Worked fairly well for hard wet use. Not the best bet if you're trying for world TT records mind you.
Cheers,
NM
If you're saying that you have a square taper BB I would repack the bearings every season. If the bearings are sealed they won't need all that maintenence, but it would be worth your while to open the BB up and see what you've got in there.As I stated in my op above I have a screw on tapered BB and an aluminum frame. My problem is that I know aluminum threads and because they are so soft that they "shed" (my made up word) shavings of threads when you screw and unscrew them. So I'm just hesitant to do maintenance on my BB until absolutely necessary. So I'll take the chain off and see how the spindle feels and if it feels good I'll call it good.
So far you haven't told us what we need to know in order to offer advice. Square taper BB axles does not imply sealed bearings or loose bearings. If you have a sealed bearing unit then you need to pull the BB and clean/grease the threads on the BB cups but there is often nothing to be done about the bearings. Seized BB cup threads are a VERY bad thing and they need to be regularly cleaned and regreased. Some people pick the seals out and push fresh grease into the cartridges but I have 85,000 miles on my Campy Chorus cartridge BB and the bearings are just fine. If you have a loose ball BB then you should clean and repack annually unless you are not riding much.As I stated in my op above I have a screw on tapered BB and an aluminum frame. My problem is that I know aluminum threads and because they are so soft that they "shed" (my made up word) shavings of threads when you screw and unscrew them. So I'm just hesitant to do maintenance on my BB until absolutely necessary. So I'll take the chain off and see how the spindle feels and if it feels good I'll call it good.
I have a 1993? (haven't checked serial # to know for sure) but decals on bike before repaint said 2.8 R700 Cannondale. It has loose bearings.
