1 - 20 of 26 Posts
I'm new to the world of cyclocross bikes and was curious how proven (for durability) are carbon fiber forks and seat stays? Have they been incorporated on these bikes for awhile now or are these new features to help lighten the bikes and improve their comfort?
I would hate to drop $2000 for one of these high end bikes and then have durability issues with the carbon fiber. I watch a lot of F1 and those cars have a lot of cf parts, and when they break, they fail big time and just shatter. That'd suck on a bike, IMHO.
Any insight?
They don't just snap
remember. Plenty of CF MTB frames are out there. Every fork will differ as companies use diffrent tech. I've never seen one break in a race but like all equipment, there will be some that fail.
Carbon fiber mountain bikes a relatively new phenomenon. 1-2 years ago I don't think you could find anybody outside of maybe Kestrel making them. Now many of the biggies have jumped on board, but I just wonder how proven the material is.
As for how they break, I know when a carbon fiber suspension part on an F1 car breaks, it tends to just snap (or fail catastrphically). Are mountain bike parts made from CF designed or made in a different way to allow them to not fail so dramatically.
I have seen carbon bars and seatposts break, and Trebon had bar slipage probs in Boulder. I have seen the pics of Nys' C50 broken from crashing, also seen plenty of Alu/Steel frame brake too. Trebon/Wicks/Caveman run carbon rear ends, Spcialized has midlevel bikes with carbon rear, Haven't seen them break, no recall notices that I am aware of. Carbon forks are everywere,
I am not one to think that Cross bikes take MORE stress than road bikes, its just different forces/frequencies. (I am not an Engineer) Dfleck makes a good point about carbon MTBs, thats prob a better comparison of forces to cross, and not a whole lot of problems.
If you WANT a carbon rear end, get one, wether or not you NEED one is a different thread. Carbon forks are well proven.
Number 2 on the course.
Carbon can built to be very strong -- stronger than aluminum or steel -- and has been incorporated into road, CX and MTBs for several years. I think they have been proven at least a safe as any other material. If you are wary of the relatively recent adoption of CF for MTBs, consider the number of road forks that are out there on crit bikes and hitting rocks on 50mph+ road descents. I would not worry about a frame or fork "exploding" under you due to normal racing or riding.
However, a single crash, even a minor one, can total your frame or fork if you land the wrong way on the wrong piece of terrain. Once weakend just so, you can have a catastrophic failure at an underterminable point in the future. The rub is that it is it is very difficult to discern whether a part has been significantly damaged.
I'd say, if you are going to lose sleep over the remote possibility of component failure, or if you can't or don't want to replace parts that might be damaged, avoid CF. I have a full steel race bike and a AL/CF race bike and the difference is negligible.
ajoc_prez said:
Carbon fiber mountain bikes a relatively new phenomenon. 1-2 years ago I don't think you could find anybody outside of maybe Kestrel making them. .
That sould really be said "10 to 12 years ago" and "Kestrel was making crap" and to include the "Treks that were Lugged carbon (mtn and Road) and OCLVs that the Texan won all those tours on,and the C40s that had already won Wolrd Cup races on the road, and the ALAN/Geurciotti Carbon cross bikes that were being raced, ok I'll stop...
Watching the elite race at CX nats there was a rider in the elite field that crashed hard on the downhill into the Clif Bar run up. His steerer tube catastrophically failed and he went down like a ton of bricks and stunned himself good. It was a carbon fork but I did not see if it was an aluminum or carbon steerer. If damaged, either are going to be just as likely to fail and both will be catastrophic.
I'm not sure what the cause of the break was but if it was a carbon steerer the few that I have seen are typically from over tightening of the stem bolts and compression of the carbon. It's likely this could have been the case here too, but I can't say. If you have any carbon fiber parts that are under compression from a clamp (stem, seatpost, etc.) you need a torque wrench to set the bolts.
Discussion Starter · #9 ·
I guess carbon fiber has been around for awhile in the MTB world. I had forgot about some of the Trek bikes. I guess it is just now tricking down to the less expensive bikes. I don't have any experience with road bikes, and I've just been researching cyclocross bikes recently, so wasnt sure how new CF was..
I'm a big fan of steel...if I'm not mistaken, it will normally bend before it breaks. Maybe I'm making too big of a deal about this, but just thinking back to the problems F1 has with CF failing, it got me to thinking about it. And then there is possibility of damaging the carbon fiber in a crash and then wondering if it was severe enough to write off the frame. While looking at a $6000 carbon fiber mountain bike at the LBS, I was thinking how much it would suck to crash and dent the frame, then wonder if you were going to have to replace it OUCH!!
Off to do more research... thanks for all the input so far :thumbsup:
check out the podium
It was an aluminum steerer, and it brok about an inch north of the crown, basically in the middle of the head tube somewhere. He's had that bike for about a month.
pi makes wheels go round
ajoc_prez said:
What are those Bianchi's made from? Steel? Aluminum?
That is definitely an older steel model (much like the one i have).
And regarding the F1 racers - the car is designed to disintegrate. It is meant to keep the driver safe at 200+mph while sacrificing the car. A bit different design problem than a race bike.
-D
come'on guys that Bianchi is Aluminum, look at the size of the welds(the one that failed) and the diameter of the tubes.
Discussion Starter · #16 ·
-D
Actually I was referring more to the suspension pieces than the tub of the car. The CF suspension on those cars tend to be very delicate and even if they rub wheels with another driver, it can cause problems. I've even seen a few fail for no reason at high speed. Scary stuff. Granted, bike parts are probably a little different, but I was just curious if CF has been on bikes long enough for us to know its durability...sounds like it has.
Hope he's alright. That was quite a hit he took.
Any idea what kind of fork?
I'd say that carbon has been around long enough on MTBs to prove durability.
I've got a '95 Fisher (aka Trek) OCLV carbon hardtail mtb. I thrashed that bike as hard as any bike I've owned (steel, Al, or Ti) and it took it all just fine...jumps, drops etc.... The bike is still going strong doing singlespeed duty.
I can't count the number of times I had really large rocks flip up and bash into the downtube. It was enough to make me cringe, but never caused any problems.
And as for carbon failing catostrophically, I've broken a carbon seatpost and a carbon crank, and while both failed, neither one let go without warning. They both started crackling well before they failed.
Also had a friend break a CF frame, and it also gave warning.
Remember that carbon is typically formed with multiple layers of cloth with the fibers often oreinted in varying directions. A crack has to get through all of those layers for the entire part to fail. In both failures I had, I believe the crackling noises I heard was the first layers starting to give way. Everntually the others let go, but not without warning.
I've got a friend who'se aluminum road bar snapped without warning sending him to the ground ending with a bunch of pins in his elbow. Maybe there was a crack visible at some point, but I highly doubt most riders inspect there bikes for cracks. So in that respect, aluminum doesn't necessarily give any warning.
As far as part failure, aluminum doenst give me any more confidence than CF. Bonding points between materials (say between a carbon fork and aluminum steerer) is what worries me more than the carbon failing.
And as for carbon steerers failing from overtightening....well......that's why I work on my own bikes and nobody else touches it.
If it were controlled closely and two bikes were made to identical specs, one being steel and one being carbon fiber composite would there be a fundamental difference? It depends on a lot of variables. Obviously carbon composites can be engineered to be very strong (the 787 brakes are carbon fiber because it offers benefits over previous brake materials used on planes). There is a paraplegic athlete that uses a carbon fiber leg that acts like a spring.
Only in the uber-light category of bikes would I be wary of a bike being fragile. Bike manufacturers do not want to be sued out of business. There is no motivation for any company to put out a product of any kind, such as a bike, that is not strong enough to be nearly idiot proof. There is just too much risk.
Why we see forks made of carbon fiber vs steel or titanium on many bikes is because the engineering specifications of a bicycle fork favor carbon as being the best material. While steel can be used successfully it is much more difficult to design a fork that would be light, yet compliant in one plane and stiff in another.
Get what floats your boat.
1 - 20 of 26 Posts
