I am about you height and weight and wear either a medium or large. A small may just feel "snug" but a day on the bike may have your nether regions regretting wearing a small.
numbness? The small does not feel bad at all. THe medium feels fine, not skin tight just fine, like it fits.I am about you height and weight and wear either a medium or large. A small may just feel "snug" but a day on the bike may have your nether regions regretting wearing a small.
the small is moreso tight on the shoulders fine on the legs. Wearing them rn on my computer with underwear, doesn't feel bad.numbness? The small does not feel bad at all. THe medium feels fine, not skin tight just fine, like it fits.
Anything is possible. But I think a lot of people wear their bibs too large.My question is, is it possible for it to be too tight? I'm 5.9.5 170lbs so...feel the medium maybe is the better fit? I just dont want something to loose..
Bibs should be a bit snug on your shoulders when you're standing, and then comfortable when you're bent over on the bike. That's a good fit. If they're snug while you're on the bike, then they're too tight.the small is moreso tight on the shoulders fine on the legs.
really? Now I am wondering if I should have went large, but large was a bit loose in some areas. Small was too tight, but was doable.Yes, many sizes can feel ok. The long term problem is the tighter the fit, the more it stretches and the quicker it will wear out.
Yeah but don't sizes vary? I heard castelli is pretty tight. THe small straps were a bit unbearable sitting upright straight, they were...okay in a hunched position. Maybe medium is a better fit. Also had some sit bone pain wearing them! funny enough...Anything is possible. But I think a lot of people wear their bibs too large.
I like my bibs TIGHT. If they're not tight, they ride up my legs, bunch in the crotch, chafe like hell, don't hold the boys in place.
I'm your height. I run 160-170lbs depending on the season. And I wear a small. I don't find them too tight, even after 100mi.
At 170, you're right on the border IMO. If your weight fluctuates above that, you might be better with a Med.
I see people ride with bibs that are loose around the legs... like you could slide a finger or two in the gap around their leg. WTF? You're defeating the purpose.
In terms of overall fit, however, you should aim for your bibs to be like a second skin, worn tight to the body. Loose material or gaps can cause chaffing and put an end to any ambitious rides over long distances.![]()
Wiggle's bib shorts buying guide
The purpose of bib shorts is simple - they prevent your shorts from riding down when you're in a low riding position without requiring a restrictive waistband, but over the years, an explosion in innovation and development has made the bib short essential, providing new levels of comfort and...guides.wiggle.co.uk
Bibs should be very tight fitting. They should cling to your legs without moving in order to reduce chafing and increase aerodynamics.![]()
Why you should wear bib shorts and what to look for when buying them - Canadian Cycling Magazine
These stretchy bottoms will massively increase your comfort on the bikecyclingmagazine.ca
The straps should fit snugly over the shoulder but shouldn’t feel too tight. Bend over in a cycling position when you’re trying on bibs—most are designed for cycling not standing up.
They do. But I was talking about Castelli since that's the brand you were.Yeah but don't sizes vary?
If they're borderline unbearable, then yea you are in the wrong size.I heard castelli is pretty tight. THe small straps were a bit unbearable sitting upright straight, they were...okay in a hunched position.
