1 - 12 of 12 Posts
Here is the deal, I can get a QR tri bike with 105 components for really cheap but I have no desire to race but I do need a solid commuter bike. How hard /expensive /feasible would it be to covert this bike to a commuter bike with drop bars?
Thanks
Premium Member
Some problems you will encounter...not that it can't be done..
1. The geometry is tight and the angles are steep on a tri bike- translation- unforgiving ride
2. There is usually very little tire clearance on a tri bike.. 23c might be the maximum size...not good for potholes
3. Tri bikes usually have short headtubes- get used to be bent over or use some super tall stem/riser...
If you don't mind the above, go for it...
I was worried about this..... I might keep looking
thanks
angel of the morning
Thanks
depends on the bike .... if it's an old school Dave Scott Centurion Ironman then I'd think it'd make a great commuter .. slightly longer wheelbase, slack seat tube angle, easy to set up with different bars.
Failboat Captian
I don't remember what it's called, but what's that attachment that extends the wheelbase to make a bike look like a Surley Big Dummy? That'd be a classic attached to a QRoo tri bike!
The web is a MUT
Discussion Starter · #9 ·
1 - 12 of 12 Posts
