1 - 3 of 3 Posts
Off the back
I bought my frame from a sponsor of this site. I asked them to install the BB which I had bought for my FSA double compact crank, a 108mm. The bike came just fine, I built it and rode a few times. I kept throwing the chain over the small ring on front downshifts and got sick of it. I took it to the LBS and had them diagnose.
They tell me the wrong BB length was installed and the one in there was for a triple!! They installed a like model 108; the bike indeed shifts more reliably.
OK, I could use a new drivetrain on my commuter and have need for a triple BB. Except, I'm not positive of what I have.
It's an FSA Platinum Pro Titanium. The only markings which COULD be size are:
801.37" x 24T (I'm assuming the 24T is a thread pitch and that 801.37 doesn't convert to anything metric) and NN122 (Their's no such thing as a 122mm spindle)
It measures (as best I can) 4 5/8" which converts to 117mm. Besides, exactly which two points are measured from?
So, what in the wide, wide world of sports do I have? I think it's 68x118, but I'm not positive. I have an email open to FSA tech support, but no answer yet.
Thanks.
Dave
measure from outside of the axel ends. the one you have sounds like the 118. one way is to compare lenghts to the shimano counterparts. a triple ultegra is 113- 115, triple campy is 111mm for example. i had a bb uncrew on me because the shop installed the wrong lenght. sell the triple on eBay. visit http://www.fullspeedahead.com/fly.aspx?layout=product&taxid=29&pid=72 to see the info on your bb. Measure from BB shell to either the center of a double crankset or the middle chainring (on a triple crank) to establish chainline dimension. then go to shimano for whatever your running and see they would recommend. Chainline dimension determines spindle length. refer to http://bike.shimano.com/media/cycli...ponents/FC/SI-1F30H_v1_m56577569830572764.pdf for shimano......
ISIS BB spindle length, threading
From the discription, it sounds like it must be an ISIS splined spindle. The ISIS standard calls for only 3 different spindle lengths - 108mm, 113mm, 118mm. 4 5/8" works out to 117.475mm, so your BB must be a 118mm.
The marking 801.37" x 24 TPI must refer to the threading of the cups/rings. A standard English BB shell uses a 1.37" x 24 TPI thread. English threaded BB shells come in only two widths - 68mm and 73mm. 73mm is found almost exclusively on mountain bikes, so your road BB shell must 68mm wide. My best guess is that that 8 refers to 68mm, and the 01.37" x 24 TPI refers to the threading.
1 - 3 of 3 Posts
