Is this a triple or double chainring?
http://www.performancebike.com/shop/Profile.cfm?SKU=24098&item=50-3562&slitrk=search&slisearch=true
It's just that the teeth and ramps designed to lift the chain won't line up. - TFsteel515 said:also if I mix 39A and 53B, is that very bad?
They should say. You may get a correct answer if you call. If it truly is "Ramped and pinned", then it is for a triple. The inside ring of a double doesn't need any pins. - TFsteel515 said:Is this a triple or double chainring?
