DT 240 hubs: The cartridge bearings are easy to change, well, most of them. You pull the freewheel carrier off by hand. You tap the axle out. You tap the bearings out of the freewheel (some models have a snapring that has to be removed), and bam, three out of four of the bearings are in you hand. Problem is, the bearings are pretty small ones, so although they're pretty light, they're going to need to be replaced relatively often. Second problem, is that the first one that seems to wear out, is the fourth one of the four that you didn't get out with simple hand tools. Make sure your bike shop has the special DT swiss 240 hub tool that will be needed to get to that fourth bearing before you let them sell you hubs. Same goes for high end bontrager wheels, as they use the same hub design from dt swiss. Anyhow, the tool only comes as part of a $120 or so kit, so most shops don't have it, and are unwilling to buy it. I ended up having to buy the kit myself. No shop within 100 miles has the thing...
Shimano DA hubs. Hey, if you're already using 10 speed drivetrain, you can't beat the 7800 series hubs. They're shiny. They're light. They're smooth. They have traditional bearings. They come apart with traditional tools (cone wrenches) for repacking. Be careful comparing weights between these and the DT models, as I believe they are specified WITH the skewer weight, whereas the DTs are specified without. They're light, and they're approved for radial lacing (DT models have radial specific models, which are a bit heavier, as they're thicker at the flanges). They actually have really great axle seals, so don't pay attention to the myth of "cartrige bearings have better seals." Frankly, these are great hubs. I'm considering owning another set. The deep sines of the aluminum cassette carrier keep it from getting gouged like the DT carrier will, although it's also the reason you can only put a 10 speed cluster on them.
Shimano Ultegra: I've only seen them from a distance, so I can't comment. They look stout, and they take a 9 speed cluster, although they weigh more since they have a steel cassette carrier rather than the aluminum of the DT or the DA.
Now that I own the tool for the 240 hubs, I'd rather service them than my DA 7800 hubs. However, I suspect that the internal parts (good bearings are $8 apiece, star ratchet sets are $40 or more) for the DT hubs will be pricey to replace. I feel like my DA hubs will roll longer with less maintenance, whereas the 240 hubs would need atleast some of the bearings (two of them are subjected to much higher stress than the two others) fairly frequently. I don't reccomend against the 240 hubs, I'd just make sure you have access to the special tool first. But if you're running ten speed, you can't go wrong with the DA hubs.
For what it's worth, the DA hubs come with nicer skewers than the DT hubs.
(my DA 7800 hubs laced 28 hole to DT R1.1 rims with butted/bladed spokes are lighter than my ksyrium SLs)
Further, I own four sets of chris king hubs, but I haven't had to do anything more to any of them yet than regrease the drive rings. Once they need new bearings/drive rings, I'll have to buy the $150 special tool for them, and I'll probably feel the same way that I do about the DT hubs.
