1 - 20 of 23 Posts
Frog Whisperer
On top of everything else in my life, last week my sister (who lives on my land, rent free in a mobile home that I own) asked me if I could replace the kitchen faucet for her if she got one. Ok, any of you who have EVER worked on a mobile home know that NOTHING is standard and EVERYTHING is proprietary. No shut off valves under any sinks....what a nightmare. They are plumbed with non-standard, flexible tubing with crimp fittings. To make a long story short, it took me 6 hours and 3 trips to the hardware store, I bought 6 valves, returned 4, had to take the sink out because even with the basin wrench, the old faucet was NOT coming out in place. Had to fabricate pipe nipples out of the stubs off of the old faucet and modify the sink to accommodate the flexible and rigid tubing coming out of the bottom (entailed grinding a cut out on the center hole so it would fit properly).
I came damn close to taking her dog out for a walk and leaving a pile of newspaper on the stove with a burner on!
BUT...it's done....and it doesn't leak anywhere.
Shirtcocker
I stopped reading after this. :eek:
Frog Whisperer
yeah...it's official, I'm a moron...
Frog Whisperer
at least it didn't leak when I left it...maybe I should go back over and check?
your text here
last friday i had to wrestle with the pos faucet in the powder room. faucet wrench wouldnt work because the nuts were huge (haha), so i had to use my giant set of channel locks. then i couldnt get the couplings to fit right. took much longer than i thought. blood, sweat, and swears.
when i got done The Wife asked what was for dinner. i burned two cheese quesedillas and called it a night.
Frog Whisperer
huge soft plastic nuts!
Moderatus Puisne
Have we gone over the part where you're whipped?
// always amazed by the people who actually can, you know, fix stuff.
What the what???
At least not anywhere that you can see :)
Plumbing projects are never done...they are only deferred for a while...
One of my riding buddies is a retired plumber and will do most anything to get out of the house.....I haven't even thought about doing home plumbing jobs since meeting him. Cheap too.
You need to lean how to spell ................... it's moreon.
Captain Obvious
i have a rv. i empathize with your anger.
I work with a CNC programmer who is a perfectionist, his son is a plumber and has the same quality. I call him for every plumbing job now -- the few dollars it cost is much better than the headaches of plumbing, which I know all too well. On another note, a friend had to replace a sink in a condo -- the idiots who installed it put it in with liquid nails. He had to borrow a hydraulic floor jack to break it free.
Boobies!
I always figure on at least 2 trips to the store for any plumbing job, but THAT sounds like a complete PITA
No leaks though--so it's a win!
My last pluming job was a one-tripper and a total of zero 4 letter words, I was amazed. I had to replace rotted out drain pipe under the kitchen sink. The only thing left was the chrome.
25.806975801127
I wrote a bit on my house blog about how much I hate plumbing. I won't bore you with that, but I'll poast a couple of pictures....
Before (sorta)
After
All projects are deferred for a while.
I am convinced that about every 7 years it is time to do all the maintenance on a house that you did 7 years ago. I'm painting the garage door, the front bay window, and all the window sills on the exterior. On top of that, the garage door just broke and it is the exact same piece I replaced 6 years ago. That happened tonight. The weather proofing on the deck looks like it has another year, maybe 2 at the most, and that was done 5 years ago.
Don't even get me started with car projects. There is always some noise coming from somewhere, a tuneup, or an oil change that needs to be addressed.
The projects are always ondoing for the handyman.
Kudos to TouchoGray. I would have set the place on fire. Spent 6 hours trying to fix the heater core in my wife's Sonata and hadn't even seen the heater core in that time frame with most of the dsah, the front seats, the center console, the steering wheel, and air bags sitting in my garage. Decided it was time for a new car.
1 - 20 of 23 Posts
