1 - 6 of 6 Posts
I have 27" wheels on my Schwinn Traveler, and while I eventually plan to change to 700 wheels, I feel that the wheels I have are in good shape. I would like a wider slick tire than 1.25", though. I have not yet been able to find any listed online at the stores I am familiar with. Does anyone have any suggestions? Based on what I can observe, taking into account the frame and brakes, I think I could fit 1.5 or even 1.75 tires.
(Explanation: I rent a house located on a farm, and have a dirt driveway and lanes. My daughter is learning to ride her little bike, and I would like to be able to dink around the farm with her as far away as possible from the road while she is learning.)
Have you tried HarrisCyclery.net?
They show some 27in. tires on their website, but the widest is 1 and 3/8 in. and they are not slicks. But, perhaps they would know where you might locate what you want. I sent a couple of e-mails to Sheldon Brown at Harris Cyclery about a 70s Raleigh that I have. He responded very promptly to my inquiries. I have no afiliation with them and this not an advertisement. I just know they have a supply of older parts. Good luck!:p
Do you want wider tires for better grip or for puncture resistance on the dirt roads?
If it helps, I run 27" x 1.25" Specialized Armadillos on my grocery/beer bike, and I ride it on dirt and gravel paths without any problems. I get decent grip, as long as I keep the speed relatively low and don't make any severe turns. I too wanted wider 27" tires, but the ones I chose work just fine.
I need a more stable "footprint" for our lanes, as most of them are sand. Probably I would be better served just to get a junker MTB with knobbies. The 1.25 Kenda tires currently on the bike roll fairly well on hardpack or in the yard, but when I hit the sand, I sink in to the spokes.
Through trial and error, I haven't found anything that really works well in sand. Even with 2.0" or 2.2" MTB tires, I lose traction easily.
You might be better off with a MTB or MTB tire nonetheless. If you're looking into it, a Redline 29er might work for you as it's reasonably priced, and you can switch out wide knobbies to Cyclo-x, or road tires. It's a singlespeed, which may or may not be to your liking.
A cheap solution might be to get a 700c wheelset, and try running cyclo-x tires; I have a feeling though that you'll see only a marginal improvement in grip, and you'll wind up spending the same amount you would on a new inexpensive MTB. The folks over on MTBR may have more advice on sand cycling for you...
1 - 6 of 6 Posts
