brewster said:
Do share some painting techniques such as how you masked the lugs and what paint type was used and the application method for the paint. Looks like that will give some new life to an old faithful. I too like your choice of colors. I have a few projects that I don't really want to spend big bucks at a professional painter that I've been tempted to try a home job on. I'm just afraid I won't be happy with the results.
brewster
The only thing that is not available cheaply is the sandblaster I used to stripped the old paint/rust off with. You can use airplane paint stripper and then a course wire wheel if you can't get a frame sandblasted. Otherwise it was all Rustoleum rattle can. I used the Rustoleum automotive primer, wet sanded a little, then applied rustoleum white where on the head tube and downtube, wet sanded, masked of the headtube with very thin strips of masking tape to make the radius of the curves around the lugs (took about 2 hours to do), then masked off the panels with paper and tape, applied Rustoleum Red and took the tape off as soon as I could that way the tape and paint did not bond, wet sanded and then applied Rustoleum Clear Coat. Done. It is not perfect but the overall effect for 30 dollars in paint, sand, and sandpaper is pretty much worth it.
