1 - 16 of 16 Posts
the fist
walkway that is!:p
The north side of the house receives little sun and the grass growth in negligible with a planter running the length of the house.
The dogs stomp down any chance of growth by the gate into the backyard, as well. So, I am thinking about putting in a walkway from the drive to gate.
I'll need about 26' x 32" of stamped concrete pavers (generally 16" x 16") or flat river stones. I am leaning pavers.
What no i need to do to prep the ground?
This thread would have been more appropriate if you had waited till monday to post it.
Not a rocket surgeon.
Did it down 3-4"
Level is with some crushed road base and compact it well.
Slap down some pavers and call it good.
had it in the ear before
i got higher than giraffe ***** this afternoon
the fist
JohnHenry said:
walkway that is!:p
I went to home despot (where all the dictators go for home improvement!!) and Lowe's..which was probably a mistake
The recommend down around 3" and then use sand. I see below road fill is recommended. It seems like sand would pretty quickly dissapate (sp?). how about a combo of the two?
What about removal of the 3" 4" of earth removal? Shovel? tiller? back hoe (ungh)?
Not Banned
dig 3 - 4 inches
add a bit of small river gravel (helps drainage) and sand, lay paver
go Japanese style, think of the stones as river, flow, flow, rest (like a pool) so as you walk it is step step stop and contemplate,
get thick stones so they extend a few inches above ground level
plant wooly thyme, baby tears in between.
if it is wide enough make a small table and chairs and you'll find you have a lovely little retreat on hot days
Non non normal
I would like to help you get stoned but I can't throw the first rock....
Frog Whisperer
HEY...I just read this (yeah, after I posted, go figure) you ever seen the plastic forms they sell at the home centers that you lay on the ground (or dig down 3 inches ) then pour quick-crete into?.....the wok REALLY slick, 2 years into the first walkway and going to put more in as soon as I get time. NO GRAVEL..........and I live in WI, you are pouring on UNDISTURBED soil!
60 lb of quickcrete does two forms (7 individual blocks) and takes 5 minutes PER, you mix it stiff and move on before it sets)
Escorted from the White House
The Devil Went Down to Jamaica (w/apologies to the Charlie Daniels Band...)
Le Misérable
No matter which route you take, pounding the shyte out of the support layer is key. I've done this twice, once with a rented 'pounder' (I have no idea what that tool is properly called) and once without...and the without path cracked a little and went more uneven than I would've liked within a year or so, although it stabilized and seemed to be fine after that.
Besides, the tool is really cool...we flattened a number of different things with it during the last couple of hours before it had to go back to the rental joint:). It can flatten anything. Anything.
road bike resurrector
Formosan Cyclocross
Stop! Stop, will you?! Stop that! Stop it! Now, look! No one is to stone anyone until I blow this whistle!
Do you understand?! Even, and I want to make this absolutely clear, even if they do say 'Jehovah'.
We just call them compactors, ill add my two cents also. Whenever we do patio's or walkways we have a base layer of 2-3 inches of what we call jock sand. It drains but is also very compactible. I dont know what everyone else calls it but its made from stone dust at quarries and has a blue shade... HTH
1 - 16 of 16 Posts
