1 - 20 of 49 Posts
midnight melon mounter
Discussion Starter #1 (Edited)
The ignitor on my gas grill has stopped sparking. The button depresses and I get the same strong 'click', but no spark.
It's under warranty, but is there a simple maintenance procedure I could do to get it firing again? I sho don't want to remove the whole mechanism and send it back for examination or replacement.
edit - Folks in the office have advised me to hit the electrode with some fine sandpaper - edit
Thanks folks.
Alex
scruffy nerf herder
those things are simple to fix. About as easy as a light bulb. You can get the ignitor or the switch for relatively cheap at the hardware store... seriously. A couple of questions. If the gas is working then you might try it with the top closed first, to build up gas...but if that still doesnt work, then I would say it is the actual ignitor tip. A lot of times if you cook a lot, grease and sauces can land right on top of the ignitor. So, pull it out, clean it off with water, let it dry and then give it a whirl again. Id give it 50/50 you can salvage it.
imbasilical moreon
Weber?
Living in Evanston I assume you have the "local grille" ... Weber ..... It might be cheaper to buy a replacement ignitor from Mennards or the Evanston Home Depot than pay shipping charges to Weber for your under warranty ignitor. $8.98 at Home Depot:
Discussion Starter #7
Thanks Nug. Would you hit the electrode with a little sandpaper, as my office dorks suggest? Or are you talking towel and Formula 409?
Discussion Starter #8
Vermont Castings.
I'm amazed a Weber anything is less than $10. The Weber chimney starter was like $25.
Discussion Starter #9
I think this is Snapdragen's fault. She killed my clothes dryer last year.
Another solution is
1) Strike match
2) Stick in hole on side of grill
Discussion Starter #11
That's what I've been doing, but from the top. I decided it needed fixing when I lost all the hair on my knuckles.
scruffy nerf herder
just remove it and take a look at it, either it will have gross crap on it, or it will have a whitish film on it. honestly, the sandpaper will be a perfectly effective method.
Discussion Starter #15
Thanks. I see now that your first post specified water. I'm a bad reader.
I bought the floor models when I puchased my last two grills, so they were already assembled. They both came with the ignitor disconnected tuck up under the grill. I'm guessing that's a safety measure they take on the floor model. I've never bothered to hook the ignitors up and used the match method for the last decade or so.
Scot
Beetpull DeLite
If you're unsure about it working or not, head over to PaulCL's house and hold it under his Mother-in-law's Caddy while triggering it. Then we'll solve both problems!
1 - 20 of 49 Posts
