1 - 4 of 4 Posts
I recently picked up a TriSpoke carbon wheel (not the old Specialized Trispoke-now-HED 3, but an actual "TriSpoke" brand wheel). It looks more like the old Spin trispoke, with double concave spokes rather than the straight-sided carbon spokes of the HED/Specialized, which I also have. I'm curious if anyone knows much about the wheel; it's a rear, freewheel type, and I was wondering if there's any chance the axles will interchange with my HEDs, for which I already have front, rear QR, and rear track axles. Anyone know? Are the TriSpokes an older or newer version of the Spin wheels, or just coincidentally similar in shape?
Banned forever.....or not
I have an older Specialized Tri spoke that I bought, 2nd hand more than a few years ago. I got it dirt cheap because it was set up for a rear freewheel. I looked all over for an front axle kit, but couldn't fine one, so I took the rear axle and cut it to the correct length for a front, and ground down the OD of the axle (where needed) to fit a front drop out. I've got a grinding wheel in my garage, so it wasn't a big deal. (I guess you could use a file, but it might take an hour to do the same thing)
HED 3 is the same as Specialized...
I guess you found a solution, but the axles for your Specialized wheel are available from HED. They purchased the technology from Specialized and parts are interchangeable between the HED 3 and the Specialized trispoke. I have two of the Specialized wheels, both with freewheel threads, and I have track, QR front, and QR rear axles for them. I bought the front and track rear axles direct from HED. I'm hoping they'll fit my TriSpoke brand wheel, but if not, thanks for the tip.
1 - 4 of 4 Posts
