Wool is a miracle fabric up until it absorbs a certain level of moisture. Polyester doesn't absorb water which is one reason hi-tech fibers will tend to pass moisture through the fabric. However, cycling can often generate enough heat and sweat to overwhelm any fabric.
I've been using merino wool as base layer under polyester, and vice- versa. Wondering whether the polyester will draw moisture from the wool if it is on outside, or whether the moisture absorbtion of wool will help keep the polyester dry.
Is there any consensus on how to layer these two materials? FWIW, I have a duofold wool/polyester knit to that is wool on the outside and a mix of wool/polyester on the inside.
