Anybody who have tried installing 25mm on Cyfac Gothica bike? Does it fit on this bike. Thanks
You also need to realize that there is quite a bit of variation between one 25mm tire and the next. Reported widths (and of course that depends on the rim used) range from 23 to 27 depending on which tire and which rim. If you have the bike you can look to see how much clearance you have between the top of the tire and the fork bridge or rear brake bridge. Putting on a larger tire means that your tire will be that much taller as well so if you use the same brand/model of tire a 25 will be 2 mm taller than a 23. You can easily see if you have the clearance. Of you don't have the bike then it's kind of a crap shoot unless the mfgr says it'll take a 28 or larger.Anybody who have tried installing 25mm on Cyfac Gothica bike? Does it fit on this bike. Thanks
