So I bought a Garmin Edge 305, HR and Cad. Installed it yesterday and the darn Cad unit wouldn't work. Little test light doesn't turn on. Just no workie. Decided to replace the battery (good for Garmin, it is a standard CR2032 and you can get replacements everywhere) and see if that made it go. Opened the battery compartment and they installed the battery upside down at the factory!
Now, I don't know if they are doing this on all the units or if it is documented in the fine print, but how does a normal person figure this out? There are no markings inside the compartment to tell you that neg - needs to be up. Anyone else have this problem?
So far, seems like a really well designed and thought out product. The documentation is pretty light on some critical details. For example, battery install, installing the speedo flag on the cadence meter (you had better figure out that backing out the screw will allow it to move), and what map to buy. Found a reasonable forum http://forums.motionbased.com/smf/index.php?PHPSESSID=7c574ef2d6bfcdb8fe0deeb8ca4070dd&board=55.0 to look at for map stuff.
Going for my first road test after lunch today.
