What's the point of Shimano manufacturing special reinforced connector pins when you have to remove a few links from a new chain prior to installing it. I thought the premise is to provide users with a special connector pin to reduce the chances of failure through a poorly connected chain. Surely then, by virtue of the fact that you're removing links, you run the chance of creating a poor connection by breaking the chain in a place other than where the connecting pin joins the two ends. Not so?
