TRP is a brake company that offers some great choices if you are in the market for disc brakes on your road bike. The HY/RD model is an open hydraulic system that is compatible with all current existing cable actuated levers. The HY/RD has the following features:
- True 'plug-and-play' compatibility with ALL existing cable actuated systems
- Hydraulic reservoir provides automatic pad wear adjustment
- Works with ALL cable actuated road levers
- TRP's own ultra-grippy semi-metallic pad that is Shimano compatible allowing for further customization
- Available in black ano with polished cap or polished with black ano cap
- 140mm or 160mm rotor options will work for both front and rear
- We always recommend using 160 front
- 140 versions include our L2 (140R/160F) IS to PM adapter
- 160 versions include both L2 and L3 (160R/180F) IS to PM adapters
- Post mount to post mount adapters available separately
- Weight: 195g/caliper per wheel
The HY/RD is available now and has an MSRP of $149.99 (per wheel).
httpv://www.youtube.com/watch?v=IA3YZVFtvc0
In this video, Lance Larrabee of TRP shows us some of the highlights of their new brakes.
The TRP Spyre is a mechanical disc brake for road bikes that has great power and is also easy to set-up. The Spyre has the following features:
- Dual sided actuation
- Even pad wear
- Easy adjustment and set up
- Available in gloss black with silver actuation arm
- All mounting hardware, rotor, and adapters included
- Weight: 154g/caliper per wheel
For more information, check out: www.trpbrakes.com
