1 - 2 of 2 Posts
Just wondering if anyone knows what the internal nipple size on the Blackwell 100s. Are they a hex shape or square? Will help determine if I can run to Sears or need to order a special driver like the new Park Tool SW-15. Thanks!
-Pete
The ones I built used brass nipples with a square socket (good nipples BTW). You should probably get the tool from BW... the Park tool is not long enough to reach. But, if you can find a long 3.2mm square socket at Sears that will fit through the hole...
1 - 2 of 2 Posts
