httpv://www.youtube.com/watch?v=zIepezS3zsg&feature=youtu.be
Irwin Cycling is ready to face gravel and gravel racing head on with its new GX Series of carbon and alloy wheels. The alloy GX series, dubbed ARLO, is available in 700c and 650b versions in a 27mm depth. The carbon GX series, called AON, is also available in 700c and 650b but in a 35mm depth. Both ARLO and AON use Irwin hubs with 42 points of engagement, Enduro bearing, and they are built by hand with Sapim spokes.
Irwin Aon
Irwin has unveiled its newest wheels.​
AON Wheel
Irwin carbon rims are combined with a quick 6-pawl rear hub in the AON GX.​
AON Key Stats
  • Rim Profile: 35mm deep profile tubeless ready UD full carbon clincher with hookless bead
  • Asymmetric rim design for better spoke tension and durability
  • External / Internal Width: 30mm / 24mm
  • Spokes: Front 24; Rear 24. Sapim D-light. Black
  • Hub: 6 pawls, 3.75 ̊ engagement. Center lock. Enduro bearings
  • Interchangeable with SRAM XD driver
  • Convertible end caps for any standard axle configurations
  • External nipple design for easy maintenance
  • Hand-built with precision and preinstalled with TLR rim tape
  • Price: $1550
ARLO Wheel
Wide alloy rims allow for low air pressure.​
ARLO Key Stats
  • Rim Profile: 27mm deep profile tubeless ready aluminum clincher
  • External / Internal Width: 24.5mm / 21mm
  • Spokes: Front 24; Rear 24. Sapim Leader. Black
  • Hub: 6 pawls, 3.75˚ engagement. Center lock. Enduro bearings
  • Price: $600
For more details grind on over to irwincycling.com.
