1 - 11 of 11 Posts
I have bought some new nitto noodle bar s(26.0 mm clamp diameter) to use with an old nitto technium stem (25.4 mm clamp diameter) I had laying around. When I realized the difference I went ahead and tried to insert the bars. I was able to spread the stem slightly allowing me to do this. But I wondered whether this extra 0.6 mm is going to put too much stress on the stem clamp causing it to break. I can obviously order a new stem, but I have been wasting lots of time building this bike. Has anyone heard of a stem breaking under these conditions?
Thank you.
Steve
Banned forever.....or not
Is a 26.0 handlebar in a 25.4 stem dangerous?
Dangerous?
Square peg in a round hole.
The above combination may cause a rift in the space-time continuum.
Dangerous?
I can handle the square peg in a round hole as I have felt that way often. However, causing a rift in the space-time continuum is much more serious!
Thanks for the laugh.
passive/aggressive
I have done it. Cinelli bar in standard stem. All the roadies chastised me and told me about the space time continuum and of course it tore, I met a great woman and now I am my own grandfather. That is tad confusing.
Seriously though, it is a difference of .6mm in diameter. Carbon would scare me stress risers and all but an old cast stem and a noodle bar. Heck you could probably pinch those between two cars at speed and still ride them for years but don't quote me on that.
There are shims which are for this specific purpose (25.4 => 26.0)
Here is a link:
http://www.benscycle.net/index.php?main_page=product_info&products_id=353
That particular site is sold out of them but its just to show you that a product exists to address it.
I wouldnt try this without the shim because even the .6mm is going to be enough to not make a perfect clamp, possibly damage your bars, and probably be a bit less safe.
Here is a link:
Thanks for the reply, but the shim works when the stem is 26.0 and the handlebar is 25.4.
Discussion Starter · #8 ·
While I am inclined to agree with you I decide to go ahead and get a new stem partly because the old one is 12 cm long and I want to shorten that slightly so I order a new Nitto that is 10 cm long.
Thanks for the help everyone!
1 - 11 of 11 Posts
