Results in a nominal increase in wear. Not really a big deal with the flexibility inherent in today's chains, but still something to be avoided.guth_c said:my big ring is a 53 and my largest cog is a 25. i use this combination when i'm on flats and hit climbs which aren't incredibly steep or long.
loud and scary? you're kidding, right?padawan716 said:I'll admit I cross-chain in that combo (53-25) whenever I need a low gear. I absolutely hate shifting up front. It's loud and scary. I don't stay in it very long though, just enough to get me up the hill or whatever.
Added drivetrain wear by briefly using the large-large combination is minimal. Added drivetrain wear by consistently using the small chainring and smaller cogs is significant. If you're only using that gear ratio for brief "roller" climbs, then it makes no real difference.Peanya said:Go to sheldonbrown.com and look up gear ratios. You can input your cassette and chainset and see what you're doing. Why not the small chainring and a slightly smaller cog? Less wear on the cassette/chain and you can run the same (or almost exact same) ratio.
From a chain and drivetrain wear stanpoint, you really only need to avoid the largest cog when in the big chainring, and it really is a minor issue. When on the small chainring, using the smallest cog will almost always result in the chain rubbing against the inside of the large chainring, and that can cause damage rather quickly. The main reason to avoid "small-small" combinations is that the chain is engaging far fewer teeth on both the cassette and the chainring, and this means a lot more "stress per tooth" and so causes faster wear.Scooper said:When on the big chainring, avoid the 2 or 3 largest cogs; when on the small chainring, avoid the 2 or 3 smallest cogs (talking about 10-speed cassettes here).
I understand. I have an older Trek and it has a front 52 42. The front der shifts like a rear der, it just snaps into place. You wouldn't have a problem shifting one of those, plus you would be stronger because you wouldn't have any low gears. I think that a lot of people don't realize that these big gear changes like in a Compact just require more precice shifting and are a little harder to shift than close gear range cranksets. That's what you get trying to get something (lots of gears coverage) for nothing (2 front gears only). I have 4 bikes, one of which has a double. I used to have 2 doubles. I could go "almost" anywhere I could go with the triple, not quite but almost.padawan716 said:I'll admit I cross-chain in that combo (53-25) whenever I need a low gear. I absolutely hate shifting up front. It's loud and scary. I don't stay in it very long though, just enough to get me up the hill or whatever.
I guess head wrench never raced, or listened to stories about racing. Sometimes you get caught napping in the wrong ring, and big-big or small-small is the proper choice until you're all sorted out again.dwbitt said:The head wrench at my lbs says "never use the big/big combo, or small/small for that matter.
