1 - 5 of 5 Posts
Discussion Starter #2
to answer myself, bontrager is coming out with a hub body to retrofit it, cost $145.
Pretty expensive compared to Zipp's solution, which is just a spacer.
The Zipp wheel that they making 11sp Shimano compatible (2012 models I believe) require a new cassette body and re-dishing of the wheel. It's more than just a spacer I believe.
I had a set and installed the 11 speed cassette body. Found out the wheel was out of dish by 3mm... not that much. You should re-dish the wheel.
1 - 5 of 5 Posts
