1 - 8 of 8 Posts
Hi, I ride a 2005 CR1 in Triathlons and I am currently using a Thompson Elite zero offset seatpost (31.6mm diameter). I have been trying to find a slick forward off set seatpost like the Profile Design FFC, but they all seem to come in only 27.2mm diameter.
I need to move just 1cm or so nearer to my handle bar, so I am thinking - is it safe to just get a setback seatpost and flip it around so I seat a little more forward?
Safety vs. feasibility
It is safe, but it might not work. Some posts don't have the angle adjustability to allow them to work in when reversed. As long as you can get the desired seat angle, safety is not a concern.
I've seen mention of reversing Thomson's for a mote TT/Tri setup... go ahead and try it, let us know!
I have a kinked (setback) Thomson Elite post (kink -10 degrees) which is designed to solve this problem. The clamp stays in same position and is clearly labelled as "front" but you simply turn the post itself around to get more seat-forward position. My post is 27.2mm but it comes in other sizes too:
http://www.lhthomson.com/elite_sizes.asp
SP-E110SB * 31.6 x 287mm 16mm SB 194 grams $ 89.95
SP-E109SB * 31.6 x 367mm 16mm SB 223 grams $ 89.95
SP-E116SB * 31.6 x 410mm 16mm SB 247 grams $ 89.95
Great post, btw.
Thomson says its ok.
This is taken directly from the Thomson website ( www.lhthomson.com/elite_faq.htm )
Q - Can a setback seatpost be turned around and used as a "set forward" seatpost?
A - Yes, the setback seatpost can be used as a set forward seatpost. No modifications are necessary. The forward direction or set forward works well for converting road bikes into triathlon bikes.
------snip-------
What it doesnt say is whether that was just for the Thomson Elite or if you could do that with both the Elite and the Masterpiece. It seems implied to me that it would be for both though.
FWIW I have used a Thomson Masterpiece setback post in the set-forward position on a road bike (when experimenting with different forward seating positions and stem lengths) and it seemed to work fine, but I only put in maybe 20 miles like this.
1 - 8 of 8 Posts
