1 - 8 of 8 Posts
Hi,
I just bought TRP and got a problem installing them on my bike.
It seems brakes have limited setup possibilities and I couldn't get them working as expected on my rear wheel as you see in my
pictures.
It seems brake holes on my frame are not parallel as they are a bit convergent. I trust TRP brakes, they work on the fork perfectly so I think they are exactly 90 degree.
Should I blame the frame builder ? It is an high end frame. I don't want to use those brakes in that way of course.
Did anybody get the same problem ? What would you do ?
· old school drop out
Is there no toe-in adjustment on the TRP brakes?
Old Mafac brakes had no toe-in adjustment, and a bench grinder could be used to take off a portion of the brake block to change the toe-in. With a modern pad, there's less material to remove, but it would still work - although the pad's life may be cut pretty short.
· Not Banned
channel locks and a vise
and you give the post arm a slight bend for toe-in. It appears in the pic his pads are toe-in, leading edge making contact first. Set them up and ride, they may work fine
There is no toe-in adjustment on those brakes.
Since the frame is an high end frame, meanwhile I sent an email to the local dealer and see what he says. The retail price (frame, fork and headset) is 3.100euro, so I think I can ask.
1 - 8 of 8 Posts
