Every day's a new lesson.
I'm building up an 80s Italian Sannino frame with parts on hand, except really the only part I had to find (and it actually wasn't all that easy!) is an Italian threaded Octalink Version I bottom bracket in 118.5 mm spindle length. (Shimano 9 speed triple crank is what I have and what I'm using, by god!.... shifting a 10 speed cassette with friction shifters!)
So, I know the Italian is right threaded both sides, unlike English. I've probably installed 4 or 5 English bottom brackets in the past two or three years alone. It's not rocket science and I've never had one iota of problems. I use a torque wrench!
So I installed this one exactly the same, - because the Shimano instructions were exactly the same for both. Put grease on both side threads. I've ridden it 2 or 3 times, maybe 3 hours total. And low and behold, today I'm going to ride 10-15 miles after work and about 2 miles out from my car the whole drive train gets really hinky. Luckily I noticed fairly quickly, but it took me a lot of looking and messing to finally notice the drive side of the BB had unthreaded. 2 mile walk back to the car, alternating with sitting on the saddle, scootering it with the toes barely touching the ground. Down a busy street, across a couple of busy intersections.
So THEN I decided to read up on Italian BB's. Found out you really have to reef on the drive side, rather than just snug it up firmly like the English ones (and like the Shimano instructions). Also read a couple of recommendations to go ahead and use blue locktite on the drive side, (some said not to). But I went ahead and cleaned it all up, put some blue locktite on it and torqued the drive side fully, and then greased and torqued the non-drive side per instructions/specs.
Wish me luck boys and girls! I guess I'll be ever vigilant with this BB, although I've never given a BB one thought after installing it in the past. I'll probably inspect this thing every ride, and maybe even take it apart in a couple of weeks just to reassure myself that the drive side can be disassembled (I've never had trouble "breaking" blue locktite before). Get back on the horse, going on a ride first thing in the AM
