1 - 10 of 10 Posts
I am looking at getting a new frame very soon. Was looking on Ebay at the KG461 close out frames. Also a 481sl on sale here at roadbikereview. Never own a LOOK before and coming off a Cannondale CAD7 frame. I am 6'2" 225lbs. What do you thing about these frames? I plan on not racing and just doing fast longer rides. I want something more easy on the body after 50-70 miles and that will hold up to my weight.(planning to loose some this year)
Either way you can't go wrong. I ride the 81 series and love it. It should hold up just fine- it isn't a "light" frame by CF standards. My only suggestion is to make sure you find the right size. My 57 Look was larger than my 58 Trek.
Either frame will be easy on the body during long rides. The 481 is traditional geometry, dual seat stays and HM carbon. The 461 has a slightly sloped toptube, a wishbone seat stay and is made from HR carbon. The 461 is a newer design made from basic material while the 481 is Look's older design with upgraded material. Both frames weigh about 1400 grams. It comes down to style and color. I doubt that the performance and comfort would differ much. I have a great two year old 461.
Trying to figure the is the hard part right now. I found a 481sl 61cm that would fit like my Cannondale 59cm top tube. If the 461 has a slight slope then the 59cm frame should work with its 58cm top tube?
Off the back
Similar size and ride 461/555 in 59cm
I ride a 59. I have proportionately short legs and long torso and am 6'3, weigh 237. My pants inseam is a 34; don't know my cycling inseam w/o checking my fitting. I'm now riding a 555 as a crash replacement for the 461 (identical geometries).
You'll be fine with the strength. I don't baby my bikes; I ride fiarly hard. No problems. In fact, my major crash on the 461 shows none to little visible damage to the bike, but it was a serious crash and I replaced it because I knew it was toast. I could sell it and get away with it, but I'm not unscrupulous like that.
You'd be quite satisfied with either. If there's a tie-breaker, buy the new frame because you know the history.
Thanks for the info. I called one of the "big" stores in Boston and the salesperson told me that I am too tall for a LOOK! If all you 6'2" riders are ok with them why shouldn't I. My inseam is 35" with a Regular torso. I think the KG461 in a 59cm should work for me. I'll let you know Thursday if my Cannondale frame sells on Ebay what I'll be getting.
Have a 36" inseam, look at the seat height of my pic by no means am I maxed out. My bar drop is not very aggressive, so I don't know what they are talking about. Both my Looks, (size 59cm), are the same dimension as a Colnago size 63. (Look Seat Tube C-C = 58.3, Colnago Seat Tube C-C = 58.2, Look Top Tube C-C = 58.7, Colnago Top Tube C-C = 58.7.) Only major difference in the frames sets dimensionally is the head tube length, which could make it difficult for someone much taller. I cut my 1/2" off my fork tube for fit so I don't think someone our size is going to have issues with that. Did just see someone 6'-5" that would have fit the frame but the bar drop would not accommodate him.
Might just for kicks ask the bike shop how a Colnago C50 would match up to you and maybe ask them what size they would recommend. Might be telling.
1 - 10 of 10 Posts
