1 - 10 of 10 Posts
Has anyone built up a set of wheels using the Kinlin tubular rims? I am considering building up a set for 'cross season and have liked the clincher version of this rim on my roadbike. Any recommendations on appropriate spoke count for 'cross? I imagine I'll use DT hubs so I can swap out the hub body between campy and shimano.
Thanks.
I've got a Kinlin tubular set I raced on all last season, worked flawlessly - 24front 28 rear Sapim CX-Ray spokes (I weighed 165 down to 150 now). I'm building up a clincher set now for training/pits and am going to keep the same spoke count but use the less expensive Sapim Lazer spokes.
Good to hear. I think that is my plan. Now I just need to find a hub set with a swap-able hub body. DTs look like the obvious choice but they are a little spendy. With cx-ray spokes I'm gonna be close so paying for a set of carbon deep section tubulars. At least these should be bomb-proof.
I don't really think you need to go with CX-Ray, but they sure are strong. My set is a SS build using White Industries hubs and came in ~1450 grams (I think) and $410.
I've got the Single Speed hub that accepts a thread on freewheel, so a different beast all together. I'm quite happy with mine but have heard mixed reviews of the standard road hub as well.
question
What's the advantage of using these rims over Mavic Reflex tubulars?
(other than just being anti Mavic?)
Just curious as I'm looking at a 2nd set of tubulars for cross.
Michael
www.MLKimages.com
Thanks.
Rim depth
I believe the deeper section rim (Kinlin) should make for a stronger wheel compared to the same hub and spoke # choice for the reflex. The reason for this being hard for me to explain and a bit beyond my pay grade. But wheelbuilders have explained this to me, something about a triangle that gets created between rim, hub and spokes etc.
The benefit to the Reflex however is that it is wider and provides a larger contact patch for tubular gluing. I haven't heard any complaints about the width of the kinlin, however.
I would go with whatever width is closer to what your first set is to make wheel changes less problematic.
1 - 10 of 10 Posts
