1 - 6 of 6 Posts
Have a set of xr270 rims to be laced up and the hole offset is almost imperceptible. Am I just not seeing it correctly - Are the holes offset?
This will be my first build with non-eyeleted holes. The holes “look” clean - is there a reason to “deburr” the hole where the nipple will seat?
Thanks for the help!
Not sure about the xr270 rims, but my Aeroheads (also no eyelets) were tough to notice too. I put a spoke through the hole and threaded a nipple. Then I hung the spoke and changed the angle of the rim, watching how long the nipple would rotate in the rim. You can also give the spoke a tug towards one side and feel if it's a natural path, or if the spoke is bending at the nipple. Play around with it and you should be able to figure it out.
Sounds like a good process - I'll give it a shot. - thanks
Cipo's long lost cousin
Might not have offset
I am sure that some more experienced builders will chime in but not all rims have the spoke holes offset. I have a set of the Kinlin 30mm rims at home and will check them after work but I don't remember them having any offset either....
Thanks
Thanks to everyone - laced up the first one last night.
As noted -they are clearly not offset.
1 - 6 of 6 Posts
