1 - 10 of 10 Posts
Third Coast Colnago
Yesterday when cycling I was spinning pretty hard and a gust of wind hit me head on. As the wind hit me, it stressed my cycling stroke and I felt a small pop/twinge behind my knee, about 1.5 inches below the joint between the tendons. I limped home pretty much favoring the knee. I stretch fairly well, but it was cold.
Has anyone had this happen before? How long should I lay off? How did you rehab? Did you see a sports med MD or just lay off.? Frustrating because I was just getting my mileage up as well form and speed. The only thing I can think of as a cause is that I was feel some discomfort in front of the kness, so I raised my seat about 1-1.5 centimeters Grrrr. Thanks.
ab aeterno
Just RICE. Rest, Ice, Compress, Elevate.
If you were just getting your mileage up, it's pretty obvious that this is from being out of shape, most likely a pulled muscle. I'd do some calf stretches and take a couple days off until your limp is gone.
A good rule of thumb for seeing a doctor is if the initial pain causes you to be unable to move, the injury gets really swollen, or chronic pain that won't go away with rest.
Note I'm not a doctor, my advice should be taken with a grain of salt.
Incorrect.
Note I am a doctor. My advice should be taken with 2 ibuprofen and a glass of water :thumbsup:
There's a bunch of muscles that begin and end behind the knee.
1-1.5 cm is a lot of change if your bike is already dialed in. I never change more than 1 thing at a time. With the seatpost or seat it's max 5mm at at time.
See a orthopedist. Get an MRI. Good luck.
Third Coast Colnago
Discussion Starter · #10 ·
Thanks, Doc. I stretch my achilles quite a bit so this was suprising. I've laid off a week and haven't done anything to agrevate the upper calf muscle. I may try and go for an easy ride tomorrow. I returned my seat to the original height. I ruptured (severed) my achilles in 'oo so this was a little scary. Thanks for the advice with regards to increasing seat height. Appreciate it.:thumbsup:
1 - 10 of 10 Posts
