um, yeah, take a break from squatting. I would not do deadlifts in lieu of squatting myself although deadlifts are a great exercise.
Is your form OK?
1. Do NOT use the pad on the bar for the back of your neck. The prime indicator of someone who is clueless on how to squat is people using the pad. The bar will fit on your back in a 'sweet spot' further down toward the top of your back (but not on your neck). ]
2. Make sure your knees do not go over your toes when you are in the squat motion. You want your a$$ to stick out backward and your knees should never go over your toes whenst squatting down. (the same goes for leg pressing & hack squatting too - keep your toes at the top of the platform (if not a little over).
3. Although going down parallel is great for developing total leg size & strength, it is not that necessary for cycling. When riding, your leg is never near a 90 degree bend. You can do an 'athletic' squat and not go down to parallel. This is a little easier on your knees & something that I do in recovery from a knee scope and an overuse injury. If you want to work on your hamstrings and glutes, you can get on a leg press sled - go lighter - 2-3 plates per side (or 1 if you're a little guy) and then go down deep - til your legs hit your chest. Keeping light here is key to not jack your knees. Then you don't have to push up all the way - just up 'til past 90 degrees working the bottom range of motion.
4. Do not put 2.5 lb plates down on the floor and stand on them (heels) when squatting. This is supposed to isolate your quats - but it's plain stupid and dangerous. This causes people to lean forward too much. If you want to isolate your quads, do front squats and/or hacks.
5. The best lifting knee advice I have is to never do leg extensions. They are totally useless to an athlete and cyclist pending you're doing other leg exercises (squatting, hacking, and leg pressing). Leg extensions will F your knees up pretty badly. I was doing sets of 100 w/ 170 lbs (yes you read that correctly) back when I was into lifting a lot and one of my knees is still pissed off from that winter.
