1 - 5 of 5 Posts
Low rep power
Phosphoric acid. Use splash goggles and gloves, and be careful!
phosphoric acid rocks. I use it for all the little bits and bobs. Not so easy with larger things, though. Nice to have something a little thicker but not as thick as naval jelly.
A little hint for its use - cover it with plastic, it will keep it wet longer. Also spray with water when it starts to dry, that will reactivate it.
Using it in the trunk of the Buick. A long overlooked leak resulted in heavy rust. Fortunately there aren't any holes.
GirchyGirchy said:
Try Evapo-Rust, too...a couple of coworkers swear by it and we've started using it at work.
http://www.evapo-rust.com/
that stuff is awesome too. I've used the Zep version from Home Despot, much cheaper.
1 - 5 of 5 Posts
