1 - 16 of 16 Posts
Any ride/build reports on the LaPierre HM carbon cross frame? I just picked one up.
The frame doesnt come with a fork so that is my next decision:
I'm thinking an Edge fork but IIRC LaPierre recommends a 45mm rake. Maybe a Python then? I want to stay away from Easton and the Reynolds CX forks are harder/more expensive to find. Were the Reynolds cross forks discontinued?
Thanks in advance.
I have one... raced it as my A bike last season. It's a rocket!
I ran a Python on it with no complaints. It's designed around a 45mm fork and I would suggest that you stick to that. The head tube angle on these CX bikes is very steep. (my 59 has a 73.5* HTA) So going to something with 47mm rake, like a CX20 or the Edge is going to quicken the steering up even more.... I would suggest against that. :D
Where did you pick up the Python?
Would you recommend going to a 43mm rake fork to slow things down up front a little?
I got my Python from my LBS. If your shop deals with SBS, they should be able to get one for you. They are not expensive at all. ~$400 retail last year.
Cyclocross world also sells them.
I would stick with a 45mm. I had no complaints on mine in the steering department. It's a hell of a race bike.
Get a reynolds cx fork, they might be a few grams heavier than the Python but when you start suffering from alot of brake chatter from the Python you will wish you had something a little stouter.
Any fork will chatter if the brakes are setup poorly. We have 4 bikes with Python forks and none of them chattered, after we dialed the brakes in.
I've seen a few people with Reynolds forks who have chatter as well. All of them had their brakes setup wrong when I took a closer look.
HM Cyclocross
Guys - I am looking at this bike. I have heard great things and I am thinking about getting one. I am psyched this thread started. Is the any chance you could please give me some meacurements that I cannot find on the LaPierre Internet Site? I am looking at the 54cm from center to top of collar. If by any chance you have that size, I would love to know the standover height on bottom bracket drop. I know these measurements vary greatly however depending on tires and tire pressure. - I just want a general idea. Thanks!!! I really appreciate your help.
I've attached the geometry chart for this model. Be aware that the smaller sizes have VERY short head tubes. The included headset adds back a bit of stack height, but not as much as a Chris King or the like.
Thanls for the help!
However - I still do not believe I see the standover height and BB height on that chart. Any help would be greatly apprecaited.
Why do you care about standover? It's pretty pointless, the only time you're standing over it is on the line before the race.
wow. Thanks for this thread.
I was searching for a new fork for my La Pierre. I was looking at the Alpha Q
I love my La Pierre, great race bike, but the Ritchey Pro I have on it is a serious downer.
I would not get the Alpha Q. It has a 47mm offset. This bike isn't lacking in quickness.... stick with a 45mm offset for for best result. (unless you are on the 54 or smaller.)
That Ritchey fork shouldn't be sold as a cx fork. Talk about a noodle.
I am 160lbs and like the Easton ec90x on my yeti. If a stiff fork is what you're after, the best choice is the Reynolds.
I have a 2006 Lapierre, and it too is a rocket. It comes with some fork called "Pure". It is heavy for a fork, but also very stiff. No chatter issues.
These new frames are cool, but I know that short of a HT won't work for me.
I have this frame and ran the Alpha Q CX 20 in a 47mm rake last year. This year I am running the Easton CX90 with a 45mm rake to speed up the steering. I felt the bike turned to slow with a 47mm rake fork.
Putting a 45mm rake fork on the bike will NOT make the bike steer faster.... it will actually make the steering response slower as you are increasing trail by lowering the offset.
1 - 16 of 16 Posts
