1 - 14 of 14 Posts
Frog Whisperer
got my new one ....so i decided to TRY to salvage the old one...it is/was a great laptop
ok...tore it apart yesterday, ordered an new CMOS battery just in case since it is a 5 year old rechargeable... (ML 1220)
semi stuck it back together this morning and leaving the battery out over night reset the CMOS and it tried to boot.....display and all. I mucked around a bit and ended up popping the batter out again and what do ya know...the battery holder popped right off the mother-board...DAMN...BUT..there was the original problem....bad or broken solder joint....well NOT repairable BUT (well I guess i could try to solder it back with 2 little bits of wire) I found a new motherboard (OEM) for 44.99 on line so I ordered it. Worst case scenario....I screwed up and I am out 54 bucks (with shipping)
If i get it back up and running, my son gets a good laptop.
Just Plain Bitter
Wait, I think I told you to remove the battery earlier. No one ever listens to me anymore. Either way you ended up with a new lappy so all is good.
Frog Whisperer
I thought you meant the power battery not the cmos battery which I had done repeatedly. It is a MAJOR job to get to the RTC battery so I didn't want to start on that until I had a replacement laptop. as it is, the problem was the battery holder not the battery. This way I will restore it to original and give it to the boy.....I got it down to the mother-board now so...................
Frog Whisperer
I understand this, this ain't my first rodeo...
There are at least 25 or more screws i had to take out to get the laptop apart, and given that it is a 5 year old machine, i was hesitant to break it opened without a new one configured and loaded with programs and the data from the hdd on laptop 1. I use a computer for a lot more than e-mail and the lounge .
Fact is, the bios was corrupted BUT the reason for that was a solder failure on the RTC battery holder, hence the need for a new motherboard. I was going to try to repair it and it would not be the first motherboard I soldered back together. But for 54 bucks, it just isn't worth my time, this time. I will probably fix the old board later just to prove to myself that I can...lol.
I would much rather waste my time on my bike!
Frog Whisperer
wow, MB came this afternoon, two days....I have it in and the computer is perfect again!
Canon Fodder
Did you order it through Tiger Direct or Newegg, I get most of my computer stuff through them ...Very fast most times
Frog Whisperer
Discussion Starter · #9 ·
arghhhhhhhhhhhhhhhhhhhhhhhh I left it running when we went out for a few hours last night and when I got back it was frozen solid....I re-booted a few and it was ok...but ultimately froze up every time. This morning it freezes as it goes into windows. I booted with an Ubuntu disk and it seems fine. (no hdd activity with a ubuntu live) Wondering if Windows is just so hosed that it won't work?.....OR what?
edit....no they didn't have a motherboard.....this is 5 years old
Frog Whisperer
Discussion Starter · #10 ·
scratching head now...I ran a system restore, back to July 27 before and of this nonsense and it is now here in windows working just fine. I can honestly say, I sure don't trust this thing!!!!!!!
Frog Whisperer
Discussion Starter · #11 ·
new update.... format C:\ enter......
as we speak it sits at 65%....and been running longer than at any point in the last day...LOL
I have a full set of XP pro install disks and driver so...
we'll see....................
waterproof*
just pause to consider the value of your time and what else you could be doing besides messing with computers... unless you enjoy that.
Frog Whisperer
Discussion Starter · #14 ·
considering I would be paying 300 bucks to have someone else do this
1 - 14 of 14 Posts
