1 - 7 of 7 Posts
I am a little confused about cross bikes. I owned one and liked it a lot,even though I thought it was too long. I ride a 54.5 top tube on my road bike. The cross was a 55.5(Gunnar). I put a stem on it to get it close to my road reach length. Even though it handled great, was that just a bandaid? I want it right. What are the current ideas on cross frame sizing? I have noticed the x frames seem to all have longer top tubes in relation to seat tube size. Why not ride a frame identical to your road frame? What do the pros ride, and what does everyone else ride? Like I said,my road frame is a 54.5 with a 110 stem. Perfect fit. How do I choose a cross frame. What do I look for? I will be racing local events and riding dirt roads and smooth dirt singletrack :D . Thanks people.
towerscum
NeoRetroGrouch
towerscum
What are you using it for? Serious single track? CX racing? Gravel paths? Commuting? - TF
Small local races. Mostly blasting around the cross country ski trails in the summer. Singletrack too.
towerscum
54 w/ a 110 stem and some spacers to jack it up a little higher might be a good bet. Generally school of thought is either road size or a tad smaller, I have tried both and lean toward the smaller size for cyclocross racing. A too-large cross frame is just awful.
go smaller
52 would probably do you good.
compare your road bike to your mountain bike frame, the mountain frame is much smaller. You get a lot more control over it. For CX you want closer to road then mountain but still a bit smaller.
Try a lot of sizes and see how it feels. Most i know go several sizes smaller...
More Cowbell!
I like to keep the tt about the same. My road bike tt = 55 and my cross bikes are 54.5. The cross bikes are set up so I ride a bit more upright too.
The 54 Gunnar was too big for you ... a 52 would probably fit you better. In other frames, you would probably do well on 54's -- they seem to have 54.5 tt (Redline for example). In any event, try to size by tt.
As others said, test ride some bikes if you can.
Get a frame with same TT
Get a frame that has the same TT as your road bike. Use the same length stem and maybe just flip it so you sit up a little more. Your legs and upper body will feel too cramped if to go with a shorter top tube frame.
1 - 7 of 7 Posts
