A truly like new Trek carbon frame 58cm road bike with very few miles on it. I rode it only a few times and then switched to a dedicated indoor trainer a few months later. The bike has been on a stand indoors since. You will not be disappointed.
Specifications
Frame 58cm
(Crystal White / Deep Dark Blue)
400 Series OCLV Carbon, IsoSpeed, E2 tapered head tube, BB90, disc balanced post mount, Power Transfer Construction, 142x12 Closed Convert dropout, hidden fender mounts, 3S chain keeper, DuoTrap compatible
Frame fit
Endurance geometry
Fork
Domane carbon disc, E2 tapered steerer, 15mm thru-axle
Wheels
Bontrager alloy sealed bearing centerlock hubs; 15mm alloy axle front, 142x12 rear, Bontrager Tubeless Ready disc rims
Front hub
Bontrager alloy sealed bearing, 15mm alloy axle, centerlock
Rear hub
Bontrager alloy centerlock, 142x12
Rims
Tires
Bontrager R1 Hard-Case Lite, 700x25c
Shifters
Shimano RS685, 11 speed
Front derailleur
Shimano Ultegra, braze-on
Rear derailleur
Shimano Ultegra
Crank
Shimano Ultegra, 50/34 (compact)
Bottom bracket
BB90
Cassette
Shimano Ultegra, 11-32, 11 speed
Pedals
Not included
Saddle
Bontrager Affinity Comp, chromoly rails
Seat post
Bontrager carbon, 2-bolt head, 27.2mm, 8mm offset
Handlebar
Bontrager Race VR-C, 31.8mm
Grips
Bontrager Microfiber tape
Stem
Bontrager Elite, 31.8mm, 7-degree, w/computer & light mounts
Headset
Integrated, cartridge bearing, sealed, 1-1/8" top, 1.5" bottom
Brake set
Shimano RS785 hydraulic disc, post mount
Weight
58cm - 20.08 lbs
