1 - 11 of 11 Posts
· titanium junkie
Why couldn't Litespeed ti frames have welded water bottle mount bosses? How much more does it cost to weld those four bosses? Hate those fricking rivets!
· titanium junkie
ti
axebiker said:
Once you put a cage over them you can't see them...
Well, it's not just about looks but about durability concern. Rivets have a tendency to come loose under repeated rattling from road vibration so some point in time they will have to be drilled out and replaced. It just does not make sense not to address this potential problem, especially with a high dollar ti frame.
· NeoRetroGrouch
I have 7 LS frames from '97 - '02 - no loose rivets. - TF
I do understand your concern, but the problem is if you cross thread or strip out welded bottle bosses the frame would have to come back to us for repairs, but the same issue with the rivets is no problem as they can easily get replaced by most bike shops.
Cheers,
Herbert
Litespeed
www.litespeed.com
· titanium junkie
Discussion Starter · #8 ·
Cheers,
Herbert
Litespeed
www.litespeed.com
Thanks guys for all the replies. I like the idea of a frame being easily repairable at any given local shop but I still like those bosses to be welded in place for the peace of mind and also for a touch of class. Besides, I would not want a local dealer to drill and re-pop those mounts on my frame should they come to a point to be replaced. As far as cross threading those bosses, I think it will probably take a genius to do that. If you take a look at some of the comparable priced titanium frames in the market like a Moots or even a Dean, they have their water bottle mount bosses welded in place instead of those popped in cheap looking rivets. It just goes to show that the amount of detail, thoughtfulness, and thoroughness a manufacturer put in their work to put out a first class titanium frame.
Just curious, how many of you here prefer to have their water bottle mount bosses welded in place on the frame?
· What up, dog?
To be honest, it doesn't make a bit of difference to me. It's really gotta be the LAST thing I would worry about.
I'm not trying to sound like a jerk, and please don't take offense, but it sounds like you are more into the aesthetics than the performance of your bike. LikeI said before, once the cages are on, you can't see the booses anyway. It just seems like kind of a petty thing. It sounds like you should be riding the hand-crafted European bikes rather than a proven workhorse like Litespeed. The beauty of LS is it's simplicity - especially now that they no longer have any carbon on the frames. I have two LS's because they are simple but elegant in their own right.
Would I find that acceptable in a hand-made steel frame? I don't know...I guess I probably wouldn't care that much, but on those types of bikes, that's the kind of attention todetail they are known for.
· Defender of Freedom...
To be fair to Togoat...
it does happen (I've seen 2, repaired 1 in my shop days), but like Herbert said and any shop worth their salt can do the repair.
J
1 - 11 of 11 Posts
