Hi,
I am not sure what is the best setup for a colnago c59.
I know that i can fit on either size 48s with ett of 53 with a stem of 110mm or a 50s with ett of 54 along with a stem of 100mm.
The caveat is on he 48s, i will have spacer of around 2.5 cm, while on the 50s i will have spacers of around 1 cm.
So, should i go with smaller size, long stem or should i go with the larger size?
I remember reading that colnago design the bikes with longer stem in mind. Is 110mm long enough? And will the space stack affects handling?
Thanks for all inputs
