1 - 8 of 8 Posts
Just picked up a new pair of shoes and they are rubbing against the crank. I have moved the cleat as far to the inside as possible to give me more clearance but still not enough. Are their washers that you can use as a spacer and is it safe to do something like this. Are their adapters just for this issue?
Thanks
Carbon Fiber = Explode!
Well... you can always go fixed cleats.
Shoe rub is common amongst many cyclists. The correct adapter is those "skin" protectors for your crankarm sold on ebay.
duh...
I probably has to do about what shoes you are using and where the holes are placed for the cleats. You can use washers as you mentioned. Bring in a pedal to a hardware store to get the right size washer.
Q factor
hamonrye said:
Is the distance between the pedal and the crank arm. By moving your cleats in (which you have already done) you effectively moved the pedals out, which increased the q factor. So I am thinking it has to do about the shoes you are wearing and where the holes for the cleats are placed. I have messed with my Q factor, never did anything for me. I focus more on centering my cleats.
What shoes are you wearing?
Resident Curmudgeon
Got big feet? I do, & rubbing is a minor issue for me. Like you, I've moved my cleats all the way to the inside, and that pretty much works for me. I wear size 48 wide.
1 - 8 of 8 Posts
