Interesting ... below are select results of the penultimate stage and final ITT in the 2007 TdF, a 55-km ITT over flat terrain. The penultimate stage and final ITT in the 2008 TdF is 53 km over largely flat terrain, again favoring a power rider over a climber.
Leaving the Alps and heading into the final ITT this Saturday, If the 2007 ITT is indicative of what to expect Saturday, you can group Sastre and CVV as needing at least 2 to 3 minutes time over Evans, and Schleck needing at least 3, probably 4 minutes over Evans -- to have a crack at the final yellow jersey. The wild card here is Menchov, who didn't have a 2007 final ITT result because Rabobank got booted from the TdF (Rasmussen). FWIW, Menchov finished 21st in the first ITT in the 2007 TdF (Albi-Albi) at 3:30 behind a doped-to-the-gills Vino. Menchov was also 'relegated' to super-domestique for Rasmussen after Rasmussen's success in the Alps last year, so Menchov's less-than-stellar Albi result isn't too helpful.
Barring Evans and Menchov imploding or Schleck, Sastre, CVV or Kohl suddenly riding like Ricco up the Alps, it should be a showdown between Evans and Menchov on Saturday. Of course, anything can happen in the Alps and at the final ITT . . .
1 Levi Leipheimer (USA) Discovery Channel Pro Cycling Team 1.02.44
2 Cadel Evans (Aus) Predictor - Lotto 0.51
13 Kim Kirchen (Lux) T-Mobile Team 3.00
16 Carlos Sastre Candil (Spa) Team CSC 3.24
17 Alejandro Valverde Belmonte (Spa) Caisse d'Epargne 3.37
19 Christian Vande Velde (USA) Team CSC 3.58
29 Bernhard Kohl (Aut) Gerolsteiner 4.38
36 Frank Schleck (Lux) Team CSC 5.18
