1 - 5 of 5 Posts
I'm looking for a carbon rim to replace an Open Pro on a PT hub. Hoping for somewhere between 30mm and 50mm deep. Any ideas?
Are there even medium to deep carbon rims with a 32-hole spoke count?
Thanks
Reynolds? Not sure if they do a 32 hole...might be worth some investigation.
Zipp used to but I'm not sure if they will still do custom drillings.
G
Have you considered selling your current hub and getting one more compatible with the spoke counts on a deeper wheel?
You should be able to find something in 32 hole though if you look around there are some cx specific wheels made that way. And there may be some where on the web that you can get a Zipp Pave drilled for 32 holes, that would probably be cheaper than getting it from them now drilled that way, but I do think they will still do it.
1 - 5 of 5 Posts
