1 - 5 of 5 Posts
I picked up a new 16gram CO2 inflator (Performance Hurricane) thinking it would provide more pressure than my old 12g Ultraflate. I've used it a couple of times and in each case a 16g cartidge only inflated to ~70psi for a standard 700-23c tire. That is even less than when I used 12g cartridges. It seems that after I inflate there is still a fair amount of CO2 in it once the tire and cartridge reach equilibrium. Is this an issue with the cartridge, my inflator or something else? I was hoping to get at least 100psi (the intrsuctins say 130). What gives?
NeoRetroGrouch
Do you hold the cartridge so that the exit is at the top? - TF
I use an Ultraflate and have no problems
I am stretching my memory here, but the 16g cartridges get me about 120psi. It was also the reason I stopped using the 12g inflator and moved to the 16g.
"Cypress Gardens" Fl.
Make sure when you attach the Co2 cartridge no gas escapes, and be sure to release the gas slowly into your tube. My 16g cartridges usually give me just what they advertise, about 130 lbs. Maybe you got a bad batch. Try another cartridge and see how that works. If it's still the same I'd swap out the inflator. Are you sure your tires are 700 x 23c??
1 - 5 of 5 Posts
