1 - 2 of 2 Posts
Specifically, the lower cup. I know bearing manufacture would be the challenge, but does anyone make a low stack lower half? I solved my fork issue with the shortest "long reach" fork i could find, so a lower stack cup would offset the 6mill longer fork as much as possible. Its neglibile as it is now, but im buying a headset anyway so i might as well try to get the angles 'as designed'.
Discussion Starter · #2 ·
Lower cup stacks ive found vary. The IRD techno headset has the lowest so far at 11.3mm. King is 13+, cane and fsa are 12's. Im probably down to a quarter degree change and wont notice anything so ill just go with ird unless someone has found a 10 mill stack lower part somewhere.
1 - 2 of 2 Posts
