Anybody had luck lubing their cables? Is it a good idea? I realize that this is a double-edged sword. The lube may make the cable operate better temporarily until the lube attracts enough dirt to make them operate worse.
I know Zinn advocates against lubing new cables, but what about cables that are a year old or so, and aren't performing as well as new any longer. Of course, you know you're going to have to replace them sooner or later, but can you postpone that a bit by putting a drop of lube on the cable and allowing it to run down into the cable housing?
And what is Tri-Flow, and does it significantly differ from Pro Link? Could either one be used for this?
