Yes, I am saying that the ID of the bearing is larger than the OD of the spindle.
Actually, I don't understand how this system is supposed to work. There seems to be no provision for adjustment as there was in the old BB assemblies. I would think that the spindle and the bearing should be a very close fit. Not a press fit, but just short of that. Then for side to side play (ie, along the axis of the spindle) there should be a provision for shims, otherwise once the left crank arm is tightened, the crank assembly could be either too loose or worse, too tight, squeezing the two bearings together. I can't believe that the whole thing is designed to be so precisely made that you just bolt it together and it's right.
Also, when I took the bike back the the LBS that I bought it from, they said that this sort of experience was common and the advice from Trek was to merely take it apart and put it back together again a few times and it wound then stay tight. It hasn't.
Is there a torque value for the crank arm?
So, bottom line, I can't make any sense of this. I was hoping that this was a common issue with the new precision molding of the Madone frame in the area of the BB and the head tube bearings and that a proven fix was available.
