1 - 9 of 9 Posts
I have a white 361 with the red, www.lookcycle.com emblazoned on both sides of the TT and again on both sides of the non-drive side chainstay. Would love to mask the frame off, prime those areas and paint over with a matching white. Anyone have knowledge of matching paint in a spray can?
Premium Member
White is a very hard color to match. You can try on automotive paint supply company or if it's a 51cm, sell it to me :)
Premium Member
Another Idea that will work much better. Those are decals under clear coat. Gently sand the area until the decals are gone and then clear coat the area again. It would be much easier than trying to match the white paint.
Again, the easiest is sell it to me if it's a 51cm
Interesting..
I might try some 600 wet paper and see what comes off. Can always re-clearcoat in a pinch. Also, and in deference to one's much needed sleep, the frame is a 55.
Premium Member
[email protected]!!! Good luck and let me know how it turns out. I've done it with carbon cranks. It worked fine. Just be very careful sanding. The white is pretty thick but you don't want to sand though it.
1 - 9 of 9 Posts
