1 - 6 of 6 Posts
I bought a Look 381 off of Ebay. It came with a Mavic Reflex/DA front wheel and a Mavic CXP 21/105 wheel in back. I also have a set of Mavic OP/DA wheels. Which wheels should I be using for fast rides and which ones for distance rides?
its all the same pretty much - the question is do you want a tubular front wheel?
if the front is in FANTASTIC condition, i'd probably build a matching rear if i were a tubular fan. but i'm not. I'd just sell off the wheels the look came with - u might get decent coin for the front. The rear is a pretty low quality/cheapo wheel. I'm guessing he shunted his rear and replaced it with whatever he or she could find.
OP/DA is great for anything, and for longer rides, its easy to repair a flat vs tubular. Good thing about OP rims is that mounting tires depending on brand can often be done by hand - more than can be said with many factory rims which drive me mad - and i've worked as a wrench!
Reflex and tubular
There was a time (1998 and before) when the Reflex rim was available as a clincher. The OP replaced the Reflex clincher, and the Reflex tubular continued as is. So it is possible that his Reflex front wheel is a clicher. Not likely, but possible. I agree that clinchers are most likely a better choice.
^^ that's a good catch. I've seen those i think. In any case, I can't think of any reason why one would run the wheels on the look (which are a bit of an unknown) over DA/OP.
Old, slow, and fat.
I'm riding a set of Reflex Ceramic wheels that have been going round and round for nigh on 20 years. The lineage goes O4CD -> Reflex -> Open Pro
So, to the OP: yer riding two sets of basically the same wheels. The CXP21 is gonna be slightly heavier than the Reflex, but if yer not racin, it don't particularly matter.
On a side note: one of my favorite sets of wheels I've ridden is a pair of Ritchey Pro wheels I got a few years back. Aero enough to go fast and light enough to not be too noticeable.
HTH
M
Thanks
Thanks guys.
The Reflex wheel is a clincher so it must be 10 years old. I will probably try and sell it for a few bucks.
I am going to use the CPX 21 as my trainer wheel and use the OP's to ride.
1 - 6 of 6 Posts
