1 - 10 of 10 Posts
Does anyone know the max number of spacers I can use with the Easton carbon steerer SLX road fork? I know that you cannot use too many since the steerer is carbon. Thanks! :)
The answer can be dependent on the stack height/rise of the stem, but the manufactuers have been pushing for a maximum of 4cm spacers to be used with forks with carbon steerers. Practically speaking, anything more than 4cm does bring up the question of whether or not the frame is a good match for the rider.
· Carbon Fiber = Explode!
Does it say there is a limit?
If not, you can put as many of them as you want. Some say to even put a spacer on top of your stem like a 2.5mm but nobody does that either.
Unless they say you can't do it, you probably can.
Carbon fiber will EXPLODE!
Thanks guys! 5 cm is plenty of space for me. I just want to be sure and ride safe with the carbon steerer. I'm usually more of a ti, aluminum, or steel guy. The carbon is a bit of a stretch for me.
"Not in any manuals or anything... "
yep, it isn't mention in the installation literature that comes with the fork, only on the web site. The real drag is finding out that placing the stem against the upper bearing cap of the steerer like the pros do isn't recommended. kind of dangererous.
1 - 10 of 10 Posts
