1 - 20 of 31 Posts
Ok, so I have looked all over the place, including online for these, but can't seem to find them anywhere. I am trying to find specifically a 4mm Hex bit for a 1/4" magnetic driver. I would also like to find other standard metric sizes as well, 3mm, 5mm, etc.. etc..
I broke the one that came in a Performance muti-tool I got a long time ago, but I find it useful to have not only in this tool, but just in general, so I can use it in a screwdriver.
Does anyone know where you can get these? The SAE ones are extremely common, the metric ones however seem to be non-existent..
Got a new Sears catalog today...
Sure enough, the 1/4" open stock hex bits are no longer listed. Just as a part of those monster sets.
What a PITA.
A 3/8ths set, and individual open stock bits are still available, though...
PH
Uhhhhhh
I just got a set at True Value hardware down the street from my house. 8 bucks I think. They are 3/8" drive, which is the size of both my torque wrenches and my ratchet, so it works out fine.
Kant phuckin sphell
Rollin' Stones
Easy now.
He spelled the word correctly, he just mis-used it. However, the word "retard" is going to get you both moderated if you don't cool it. I respect you both a lot more than that.
SoCal--S Beach to the Dam
Speaking of torque wrenches,what the best size to use on our bikes,1/4?
Kant phuckin sphell
For most applications a 1/4 or 3/8 inch drive torque wrench works great. But for higher torque applications you will need a 3/8 or even a 1/2 depending on the torque range.
A wrench that is accurate in the smaller ranges will lose accuracy in the larger ranges and vice versa.
Personally I rarely use torque wrenches on bikes.
1 - 20 of 31 Posts
